Gluing the nut http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=6090 |
Author: | WarrenG [ Tue Apr 11, 2006 4:58 am ] |
Post subject: | |
I was wondering whether you folks glue the nut in place on the neck, or just have it fit snugly in the slot? I've noticed a number of repairpersons "fixing" my guitars by adding a couple of drops... |
Author: | LanceK [ Tue Apr 11, 2006 5:00 am ] |
Post subject: | |
i put a tiny drop of white glue on the bottom, spread it around a little and set it in place, then I tighten up the strings, that provides the clamping pressure. |
Author: | Andy Zimmerman [ Tue Apr 11, 2006 5:01 am ] |
Post subject: | |
I actually put a tiny dot of white glue on the side of the nut toward the fretboard |
Author: | Josh H [ Tue Apr 11, 2006 5:20 am ] |
Post subject: | |
Just enough glue to hold it in place. Like Lance said a drop is really all you need. That way it doesn't go anywhere but it will be easy enough to remove and replace if needed. Josh |
Author: | peterm [ Tue Apr 11, 2006 5:33 am ] |
Post subject: | |
A little drop will do the trick.....but I guess more wouldn't hurt either ![]() |
Author: | Dave White [ Tue Apr 11, 2006 6:07 am ] |
Post subject: | |
I try and get as snug a fit as possible and then put a piece of Duck double side tape under the nut. |
Author: | arvey [ Tue Apr 11, 2006 1:24 pm ] |
Post subject: | |
Dave, You put tape under the Nut? |
Author: | Martin Turner [ Tue Apr 11, 2006 4:11 pm ] |
Post subject: | |
I make as tight a fit as I can and then put in a few drops of PVA or cyano. Oh yeah and if youre using cyano..make you wash your hands before handling any other nuts. |
Author: | Rod True [ Tue Apr 11, 2006 6:20 pm ] |
Post subject: | |
Snug as a bug and two small drips of white. |
Author: | Dave White [ Wed Apr 12, 2006 12:35 am ] |
Post subject: | |
Richard, Yes. The fit of the nut is snug in the first place, and the string pressure on the double sided tape fits it even more snugly. The tape has virtually no thickness and when you want to take the nut out it releases real easy and peels of the bottom of the nut clean as a whistle. I've been doing this for over 2 years now with no problems at all. |
Author: | 1bordeaux [ Wed Apr 12, 2006 12:41 am ] |
Post subject: | |
I fit the nut in snug; no pressure. Then a few drops of thin CA at the fingerboard/ nut joint. Been doing it this way for 20 years. Remove with a light tap from the F.B. side. |
Author: | Dave Anderson [ Wed Apr 12, 2006 12:50 am ] |
Post subject: | |
I thin out some titebond a little and apply a couple small drops. |
Author: | L. Presnall [ Wed Apr 12, 2006 1:16 am ] |
Post subject: | |
[QUOTE=kiwigeo] I make as tight a fit as I can and then put in a few drops of PVA or cyano. Oh yeah and if youre using cyano..make you wash your hands before handling any other nuts.[/QUOTE] Yes, yesterday I forgot to do this and am now typing with my nose! ![]() |
Author: | arvey [ Wed Apr 12, 2006 3:57 am ] |
Post subject: | |
Dave I would wonder if that might have some affect on sound although I imagine it would be very marginal. I've used white glue and CA but have stuck to white glue. Tight fitting nut and then a little glue holds it great yet comes out real easy. Orriginally I didn't use any glue but customers didn't like this. |
Author: | Dave White [ Wed Apr 12, 2006 4:16 am ] |
Post subject: | |
Richard, I don't think the sound is impacted one iota. I play the guitars a lot to make sure everything is fine before I finally put the tape on and then play them afterwards. That Duck stuff can be pretty tenacious. Once in a small travel guitar I made the mistake of putting some on the bridgeplate caul while the bridge was clamped on. It took me 3 days of painful contorted wriggling to break the glue bond and get the caul off ![]() |
Author: | Colin S [ Wed Apr 12, 2006 4:38 am ] |
Post subject: | |
Snug fit, no glue. If it can come out with no strings on, without some persuassion, then it's not snug enough. We don't glue in the saddle do we? Colin |
Author: | Martin Turner [ Wed Apr 12, 2006 5:03 pm ] |
Post subject: | |
[QUOTE=Dave White] Richard, Once in a small travel guitar I made the mistake of putting some on the bridgeplate caul while the bridge was clamped on. It took me 3 days of painful contorted wriggling to break the glue bond and get the caul off [: s][/QUOTE] Reminds of a guy I know who spent 12 months chasing a buzz on his classical and then discovered the bridge caul still sitting under the top.... |
Author: | Serge Poirier [ Wed Apr 12, 2006 10:06 pm ] |
Post subject: | |
[QUOTE=L. Presnall] Oh yeah and if youre using cyano..make you wash your hands before handling any other nuts.[/QUOTE] Yes, yesterday I forgot to do this and am now typing with my nose! ![]() rolling on the floor ![]() ![]() ![]() |
Author: | CarltonM [ Thu Apr 13, 2006 10:51 am ] |
Post subject: | |
[QUOTE=kiwigeo] Reminds of a guy I know who spent 12 months chasing a buzz on his classical and then discovered the bridge caul still sitting under the top....[/QUOTE] Now THAT'S entertainment!!! ![]() |
Author: | MSpencer [ Fri Apr 14, 2006 4:50 pm ] |
Post subject: | |
ColinS, I don't, snug fit, no glue Mike |
Author: | Mattia Valente [ Mon Apr 17, 2006 10:23 pm ] |
Post subject: | |
Snug (tight) fit, drop of white or yellow PVA. |
